3 blade props
Discussion in 'IMAC>>>Aircraft, Techniques, Equipment, etc.' started by orthobird, Aug 6, 2014.
  1. orthobird
    orthobird 150cc
    I just received my new Mejzlik 28.5 x 12 S 3 blade prop. i am using a 29 x 12 N prop, on my DA 170 with MTW re3 pipes.
    from looking at my new prop, (which i have yet to use), it does have blades that are wider from leading edge to trailing edge, compared to the 29 x 12 N. does anyone know if there is any major difference between the two. i am flying at 280 feet altitude, and i am getting about 6600 rpm on the ground. in the air, i am getting 7100 rpm when it unloads.
    214=53-IMG_5848.jpg[​IMG]
  2. MattyMatt
    MattyMatt 70cc twin V2
    I don't like the 29x12N... It has good RPM, but the plane feels like it is not moving through vertical snaps. The 28.5x12 pulls better.
    I personally like the Delro 3 blades better than anything else out there.
  3. Cam, if you want an IMAC guru for guidance, ^ that's your guy. If we could only get him to move to LA.
  4. orthobird
    orthobird 150cc
    MattyMatt has also helped me with my Dalton Build. he is awesome!!!
  5. jerry3672
    jerry3672 New to GSN!
    5
    0
    1
    I'll second the Delro. I'm running a 28 x 12.5 three blade on my DA150. Pulls great and is very quiet. Perfect IMAC prop.
  6. I tend to like a bit of a different feel then MattyMatt does and I kind of preferred the 29x12n over the 28.5x12 Mejzlik at least for my style of flying and airplane. I have also flown the 28x12.5 Delro and like that as well.
  7. WoodisGood
    WoodisGood 30cc
    39
    4
    8
    MattyMatt learned everything from me.
  8. I could tell by the red and black checkers on everything :p
  9. tl3
    tl3 50cc
    128
    65
    28
    VT
    Easy on the MM lovin...MattyMatt already has trouble finding hat's that will fit his dome...;);)
    Fwiw, however, I agree with respect to the 29 12N, makes a lot of rpm but not great pull. 28 12 works great on the 150, 28.5 12 likewise on the 170, and 29 12 on the 200. I can't comment on the Delro, but have heard good things.
  10. McFueler
    McFueler 30cc
    34
    7
    8
    Ty why are you running a 170 ? Last I saw ya you were running a 200 !
