30cc profile from the ashes of a 70" RIP AJ Slick - Build Log
3dNater
ugh... struggling with the wing extensions... I found that freehand sanding is not a real easy way to figure it out so I ended up making some new ones that I cut the angle on with the scroll saw. I'm not happy with the way they turn out on the hot wire... I think I'm going to make another set and use the scroll saw for everything. The hot wire is a really cool and romantic way to cut foam... but I have decided it is not a precision instrument... at all. The good news is I have the right angle. The two wings fit on the wing tube without any gaps. I have enough foam left to do about a bazillion of these so I'm sure I'll get it right... sometime.
On the current iteration the wingspan would be about 68 1/4" I think I'll make them a tad thicker and come in right around... 70" :D
3dNater
Finally after making my third set (learned a lot on the first two :p) I'm ready to sand. Word to the wise... hot wires are great for quick cutting and making wing chords etc... but really hard to use for any kind pr cut that requires precision.
The steps required to make these is to put the wings on the wing tube and bring the wings together until the long part of the wing chords are together. You might need a broken wing tube like mine ;).
Next measure the gap at the tip of the other end of the chord. In this case it was 2.5". Divide that distance in half. The angle is from zero to 1.25" over the length of the chord. I added a half inch to each end to give a tad more wingspan as well as giving the extensions a little more substance. Use a scroll or band saw to make your cuts... no hot wires ;)
3dNater
Thanks... my only regret is not being able to get it maidened before I start having to travel out of town for work. I'm already starting to need to put in extra hours to get rdy to leave on Sunday afternoon. I can see a Saturday in the office coming my way.
3dNater
Always a good day when I can get a 1/8 x 12 x 24" sheet of birch ply for $4.77 when tower wants what tower wants. I recommend trying your local Michaels or whatever craft store is close by when shopping for wood.
3dNater
I spent another short evening on the build tonight. I got the foam wing extensions sanded so they are ready to accept covering. I also got the 1/8 ply end caps cut out and got one of them sanded to perfectly match the original wing root. I ended up bolting it onto the wing with the wing bolt so the anti rotation pins were holding the ply in position. The finished product turned out really well.
I also made some ply pieces to mount the rudder and elevator servos to.
3dNater
Here are pics from tonight. Tapatalk doesn't seem to let me post pictures when editing a previous post.
