Scale 50% Dalotel 165
that should hold things together
just capped the other side of the spar, this is going to be a very strong spar, near where all the bolts are for the aluminum plates, is where the retractable gear mechanics will reside, also need to be strong
cbarnes0061;19893 wrote: I like my carbon tubes thank you very much. Without a tube profiles just can't handle to pressure.
a few things about Tube spar, one they came into being for models because of its ease of assembly at the field, two, the only tube spars used in full size aviation are on Ultralights,
No gliders, no aerobatic aircrafts have ever used a tube, so I believe , as good as tubes are, they are not necessarily the best way to go.
BalsaDust
Forgues Research;19895 wrote: a few things about Tube spar, one they came into being for models because of its ease of assembly at the field, two, the only tube spars used in full size aviation are on Ultralights,
Completly understood. Im referring to the profile planes though where they need some sort of tube in the fuse to keep them strong enough. A lot of the guys flying them actually like a fiberglass tube over csrbon as it allows for s little bit of flex when it is dorked in instead of breaking like the carbon would likely do.
cbarnes0061;19905 wrote: Completly understood. Im referring to the profile planes though where they need some sort of tube in the fuse to keep them strong enough. A lot of the guys flying them actually like a fiberglass tube over csrbon as it allows for s little bit of flex when it is dorked in instead of breaking like the carbon would likely do.
ouch, of course you don't want anything as complex as what I am doing for a little profile airplane
