Do you have another power source you could try with that rx?
Btw, Im sorry if you have already mentioned it but it will help to know what radio gear you are using as well.
Hi 3dNater. Do you mean like another battery?
I have JR 9503 and Rx is AR7010. Thanks.
Have you tried to rebind?
Yes. It sounds to me like the rx isn't getting power at all. Your esc never gives you the armed beeps, right?
Try disconnecting the esc from the rx and see if you can get the rx to respond with a battery or another esc. Basically we want to see which compo ent is having issues.
Sorry I thought I mentioned it. I do have BEC PRO and the internal bec is out of the equation since I pulled out the red wire.
This is embarrassing you were right the problem was the connection between the BEC and Rx. I think someone was messing around with my planes while I was away!! putting the plane back together now.
