60" Laser-EXP
wedoitall
Member
yea.
I guess I should look at my MXS manual again I think it has it in there. you use the longest one for the rudder? if so what hole did you use? was thinking the longest arm on the longest hole would actually be too much for the rudder
wedoitall
Member
i see in the mxs man-u-well, it says long for the rudder also. but im pretty sure im not gonna get as much throw on the laser for the rudder. i may be wrong tho. it occasionally happens. :D
YellowJacketsRC
I used the longest for the rudder and the elevator. I used the outer hole for both. But I am going to back and change to the second hole and see how that goes. The outer hole works fine but I have to set endpoints much further in. The geometry would be better on shorter fulcrum and so would the radio resolution.
YellowJacketsRC
You are correct, the Laser rudder does not move nearly as far as the MXS. Then again it is a lot bigger so it does not have to move as much
wedoitall
Member
i was thinking the 2nd on that arm for the rudder. IIRC i was getting right under 45 degrees on the lasers rudder. ill measure it again.
YellowJacketsRC
7 packs through my Laser and I am in LOVE! It has all my favorite parts from the Laser (well just a smidge less stable in Harrier) but it has SO MUCH more that it brings to the table! I LIKEY!
