3dNater
The build should go about the same. The plane is pretty CG tolerant so don't worry about getting it absolutely perfect. Close is good for a maiden and then make adjustments. The major difference in the build will be regarding the new updates that made the electric and gas versions the same. If you are going electric you get to deal with a motor box extension.
