AKNick
For the choke system... this one drove me crazy. I ended up flipping the choke arm 180 degrees, utilizing a Dubro 90 Degree Bellcrank, left over ball links, the smaller servo pushrods that I replaced earlier, and a snap ball like I got from RedwingRC.
I went this route because it felt like a "clean" installation, verses playing around with trying to get the geometry perfect for making a push-pull rod through the cowling. We shall see how long this bellcrank lasts. Note the wheel collar spacer on the bellcrank.
Also note the elaborate support stand that I made to support the throttle linkage. holy smokes... I made it so you can get to the engine mount bolt through the center opening.
