Article: Member Review: Extreme Flight 48" Yak-EXP
Feral
Member
Dudes I've got bugger all throttle response on the airboss it's like it has soft start is there a setting to change the response?
hone
If you set an idle so the prop never stops spinning that helps a bit. If all else fails reset it to default, it should have pretty good response. An idle up definitely makes a difference though, especially when going from low throttle to full really fast.
Feral
Member
Cheers home I'll try that. It's nothing like my 60" it takes 5secs to reach full power after I bang the stick up
+1! I use this on all my electrics now
Feral
Member
Idle up done still no difference:( I really don't know wats goin on here
