Scale Balsa USA 1/3 Scale Super Cub Kit " NIB "
fencelake
Here's the finished horizontal stabilizer and a mock fitting on the fuselage.
fencelake
Soooooo... It's all straight fuselages until you test fit the horizontal stabilizer... am I right?
I thought everything was perfectly straight thus far with the build. Last night I started working on the blocking that needs to be installed prior to installing the horizontal stabilizer. I actually taped some balsa sticks to kind of simulate where the vertical stabilizer was going to wind up. Everything seemed okay, so I glued the blocking down thinking it was straight.
fencelake
Once I had epoxied everything in place I did a test fit of my horizontal stabilizer and vertical stabilizer. The second to last former, and the tail feathers were square with the centerline of the fuselage, but the last former, as well as the tip of the tail were off to the starboard side by 1/4" to 3/8" of an inch. I probably could've left it alone, and just trimmed the plane later, but it would've irritated me forever.
So, when I got home from work this afternoon I disassembled the tail, the blocking and the last small former and redid all of it. What ended up happening was I had to first glue the main stringers in place making one about 1/4" shorter than the other, that way when they dried it would stay bent to the centerline. I then re-glued the small former and block. NOW it's centered up and when I put the tail feathers on everything will be square.
fencelake
I can breathe again! The tail is now straight like it's supposed to be!
