    Dismiss Notice
Canopy Refurbishment/Repair
Discussion in 'Covering and Painting' started by Wacobipe, Sep 27, 2015.
  1. Wacobipe
    Wacobipe 70cc twin V2
    Aug 26, 2014
    490
    386
    Asheville, NC
    Let's just say you had a canopy that had some light scratches and perhaps some Hysol on the surface...just a hypothetical, it didn't happen to me or anything :mad:
    Is it possible to sand those areas to remove the epoxy and scratches, and then buff those sandpaper scratches out or do you just have to throw the canopy out and buy a new one?
    Thoughts or techniques appreciated.
    @Bartman and @SleepyC ....this isn't really covering and painting....but didn't fit anywhere else either so feel free to move it if you think it belongs somewhere else.
  2. Bunky.F.Knuckle
    Bunky.F.Knuckle 150cc
    Aug 26, 2014
    2,114
    1,337
    Ohio
    Can you lightly flex the canopy to crack the epoxy and then pick at it lightly with an xacto?
    dhal22 and Wacobipe like this.
  3. Jetpainter
    Jetpainter 640cc Uber Pimp
    Aug 26, 2014
    2,910
    4,425
    Swansea, IL.
    You can polish them with rubbing compound, but if it's to bad you can clearcoat it. Terry has had some good info on tinting and clearing canopies in past threads.
    Wacobipe likes this.
  4. Wacobipe
    Aug 26, 2014
    490
    386
    Asheville, NC
    I think that could work in general...but Hysol is quite flexible so it'll probably enjoy the message and stay put! But I will try it!
  5. dhal22
    dhal22 GSN Sponsor Tier 1
    Aug 26, 2014
    1,761
    1,590
    Roswell, Georgia
    But the Hysol is only hypothetical so the theories remain that, theories.
    thurmma, Wacobipe and Alky6 like this.
  6. Bunky.F.Knuckle
    Aug 26, 2014
    2,114
    1,337
    Ohio
    I never used hysol. Only GG for me.
    Maybe mineral spirits. But check first to see if it doesnt fog the canopy or soften it.
  7. dhal22
    Aug 26, 2014
    1,761
    1,590
    Roswell, Georgia
    Every glue has it's place. Polyurethane (GG) is king of the hill in foam wing core sheeting. Hysol is basically epoxy but with a non sag advantage as well as squeeze the trigger and it mixes in the tube. Also the long tube is accurate and great for reaching into tight spots.
    I keep several tubes of Hysol, several types types of epoxy, wood glue, JB weld, polyurethane glue, Sigment, all CA's, etc. I love glue.
    thurmma likes this.
  8. Pistolera
    Pistolera HEY!..GET OUTTA MY TREE!
    Aug 26, 2014
    1,644
    2,000
    Lumberville, PA
    Well I know this guy;) who got a drop of CA on his Krill canopy. Then tried some de-bonder on the spot which made it bigger!!! Hint....de-bonder eats plastic :confused:
    It took awhile but starting with very small pieces of 600 paper I progressed to 2000. By then the circle was about the size of a quarter.
    Shifted to auto polishing compound, then toothpaste and finally plastic polish. Happy to report that it looks good as new. Took a few hours though. Lesson learned :cheers:
  9. Wacobipe
    Aug 26, 2014
    490
    386
    Asheville, NC
    Good report...not an easy operation...but good to know! Definitely cheaper than a new canopy and frame shipped from Germany. Did I mention there may be more than 1 or 2 spots...
    dhal22 and Jetpainter like this.
  10. Jetpainter
    Aug 26, 2014
    2,910
    4,425
    Swansea, IL.
    Hypothetically;)
    thurmma and Wacobipe like this.
