Thanks for this thread
@49dimes - super helpful. I've got the sensor shown below on the way to attach to my DA-120. From the picture is looks like I will be able to orient the semi-conductor as necessary to get a reading.
I plan to attach the Hall sensor to the
Jeti MRPM-AC telemetry sensor (configured as 2-pole motor) rather than a mini-tacho as has been done in this thread so far.
My ignition system uses a separate battery from the radio system for isolation with optical isolation for an ignition kill switch. The new telemetry Hall sensor will be powered from the radio battery to avoid bridging the actual DA ignition unit to the radio via the ignition battery.
I found a
diagram (note: offsite link) showing how the sensor can be wired up and supply power to the Hall sensor. But, I have a question ...
Does anyone know the specifications/part number or anything else that could help to identify the exact semi-conductor used in the Rcexl Hall sensors - I need to determine the voltage range it can handle?
My entire radio system operates at a regulated 7.4V which may be too high for some semi-conductors!
Thanks
