Wacobipe
A bit of time this evening after work to finish off the engine spacer...2 pieces of 1/4 in ply were epoxied together last night, so tonight I was able to get final sanding and clearancing for the throttle arm and fuel lines done. Once I am certain that 1/2 inch i the correct spacing, I will then coat this entire piece in epoxy resin to make it fuel proof...who knows...I might even reference that epoxy tinting thread and see if I can make it black in the process!
Tomorrow I'll string the Raven up by it's neck again...err...I mean gently support the fuselage vertically and see if I can get the engine mount holes drilled in the firewall...then I can Hysol the Firewall in!
