3D Demystifying Vacuum Bagging of foam wings!!
Here are a little photo flood of the actual bagging process. Later tonight I'll have a video up. Looks like I'm going to do my Rudder in the video.
I'm getting ready to bag my wings and need to add my unidirectional carbon first. This is not mandatory but I've been having great luck with this material. It adds a tremendous amount of surface tension to the sheeting and is super easy to use (much more user friendly than carbon tow). The material comes in sheets and is cut lengthwise with a straight edge and a utility knife. After strips are cut, it can be cut to length by scoring with the utility knife and snapping it. You will go through a few blades in your knife!!
Since I'm using resin to do my sheeting, I only need to "stick" the carbon to the foam, so do do that I'm using a small amount of non-hardening wood glue. These are glues that dry but remain somewhat flexible and don't get brittle. Just a very small amount is plenty. The vacuum will draw resin around to the backside of these strips during the bagging process. You could also mix up a small batch of resin and apply these strips with resin.
