Extreme Flight 104 Extra
I run the rudder servo in the tail on a push pull. Balanced fine with canisters. Batteries are on trays by the gas tank.
They are on top. I built trays out of light ply. They fit just fine under the canopy. I hate pull pull if I can avoid it.
[MENTION=3]GYRO[/MENTION], I'm assuming you know about the stock prop hub bolts being weak, but mentioning it just in case.
Don't use the stock prop hub bolts on the hub! @LimitlessAero will agree, I'm sure.
I did/do/don't on any of my planes. I buy the nice high carbon steel ones that are long enough for use with spinners.
