Scale F7F Tigercat 1/4 scale
more work done, all ribs and formers done, with weight reduction, probably 10 lbs, and more work done on cad as well
The Tiger cat doesn't have exterior control pusrods and its impossible for me to use the same method as I did for the Dalotel, I decided to try something like this with bevel gears, once pleased with the design, I have already started printing parts to assemble a proof of concept , then if all goes well, will make the real thing
The aileron will have rotating shaft as in this picture held by ball bearings , the servo wing rib will be reinforced it should work quite well but good or bad , I will not hide behind my keyboard :):):)
