Favorite connectors
Discussion in 'Electric Motors, ESC's, Batteries, and Chargers' started by BalsaDust, Mar 21, 2015.
  1. Xpress
    Xpress GSN Sponsor Tier 1
    Soldering bullet connectors isn't that difficult. The trick is to not only tin the wire, but to make sure the entire surface inside of the receptacle is tinned. You don't want to pool the solder up deep inside of the bullet but you don't want to have bare spots either. Takes a little bit of practice but it's not hard once you get the hang of it. I typically heat up the bullet until the solder is liquid then I push the wire in and wait until the solder on the wire wicks again, then you should be good to go. Fill in any open gaps if there is any.
    Snoopy1 and Jetpainter like this.
  2. Jetpainter
    Jetpainter 640cc Uber Pimp
    I've always kind of enjoyed soldering. :)
    Alky6 and Xpress like this.
  3. Snoopy1
    Snoopy1 640cc Uber Pimp
    4,105
    5,754
    113
    Canada
    To get heat into the receptacle you need to put a touch of solder on the iron to make good contact on the side of the receptacle so that it will heat up properly to get a good joint if not it will be a cold joint.
    Do you just put a dry soldering iron against the receptacle. If how many watt iron are you using. I am using a 40 watt iron.
  4. Xpress
    I never use a dry iron tip for anything, always wet it with some solder :) (Hakko FX888D 70w iron)
    AKNick and Snoopy1 like this.
  5. BalsaDust
    BalsaDust Moderator
    First thing I always do once my iron is heated up is dip it in my container of tip tinner.
    Snoopy1 likes this.
  6. Snoopy1
    4,105
    5,754
    113
    Canada
    Ok what is tip cleaner normally use a wet sponge to clean the tip every time you add new solder.
  7. BalsaDust
    BalsaDust Moderator
  8. AKNick
    AKNick 150cc
    1,226
    1,656
    113
    Alaska
    I think we have the same iron. I love that thing!!
  9. AKNick
    AKNick 150cc
    1,226
    1,656
    113
    Alaska
    Told an FAA inspector that I enjoyed avionics projects, he now calls me a solder sniffer ha ha ha
  10. Jetpainter
    That's now on my list for my next McMaster Carr order.
