First VPP F3P Freestyle Plane Build
AKfreak
Thanks for the kind words. I have around 40 hours total time ( I work on it off and on) I am down to final wiring (all soldered joints) and radio final programming. The AUW is around 140 grams with a 250 MAH 3S 40c packs.
AKfreak
OK its finished her, I was able to shave a little weight from my initial guesstimate. I cut off all the servo plugs, and soldered in Magnetic Wire. Now I didnt go crazy trying to shave weight. I didnt remove the servo cases, or solder the Mag Wire to the circuit boards. I did however use as much Mag Wire as possible, and I know on any future F3P builds I will go all out.
If the wind would die down a little, I would try to fly this baby. Its kind of cool to see a plane that will back up on the floor. I cant wait to learn to fly these types of planes. Also I want to say that radio setup is a real pain in the neck. I don't fly heli's, so I am not familiar with pitch curves, and throttle cuts. Its going to be extremely tricky to learn to fly this plane. It flys like a plane, except it has a reverse pitch of the prop at the middle throttle position. That is to say if you drop the throttle to the bottom (off) you will be in 100% reverse thrust.
I have never built a plane with this kind of weight. 136 grams (AUW) is nothing (Edit 136 grams w/o battery). The Slights breeze will flip the plane over on to the ground. The little AXI motor I have installed is a beast. It has a ton of power, I am thinking of going to 2S instead fo 3S.
The list of components are as follows.
Air frame Fancy Foam MX3 (It's not as advertised (it's a long story)
Motor AXI 2203/40 VPP GOLD LINE Its a beast!
Servos: Dymond Servos D 47 S Fast on the Pitch, Elevator & Rudder. Hitech HS-5045HB on Aileron and Thrust Vector.
Thrust Vector Plate: Xtreme Foamies, http://www.freewebstore.org/XtremeFoamies/Mamo_Mount_TVRP_Thrust_Vectored/p186510_6113753.aspx
MAMO UPSIDE-DOWN VPP SYSTEM for the Reverse Pitching Propeller. Also from Xtreme Foamines
Here is the fianl AUW
And a quick overview of the entire build.
[video=youtube_share;oWS3AmNMTTo]http://youtu.be/oWS3AmNMTTo[/video]
Btw I know this is a 3D forum, but playing with these indoor F3P planes are a whole lot of fun, and these planes are actually 4D planes ;)P
3dmike
Ya who would have thought 4D would happen? Geez the tech just keeps getting better and better along with the unlimited craziness we can dream up!
[MENTION=3014]AKfreak[/MENTION] Nice build thread bro. Came in pretty lightweight. And yes those VPP's are tough to dial in. Any video footage yet?
AKfreak
No vids yet, I don't want the people to see me fumbling along trying to get it dialed in. When I get a feel for it, I will make a video. hat is if I don't crash it first. I will say that thing floats like a feather. I mean I can throttle back and it just flys so slow, its cool.
alawson999
Have you flown it yet? Curious about your impressions on VPP
I built a METIS recently - went well - test flights were good - just hung it up until my indoor venue starts in the fall
AKfreak
Its way powerful. It takes a lit of time to get used to the throttle setup. It flys so easy, nice ans slow, but will get silly in an instance.
