Yes, it uses a separate switch that is not in the power feed. This picture shows the switch that comes with it. Not my photo, something I found in cyberspace.
Will a pin and flag switch work not really a fan of the slide type
Hi Scott! The R7008SB has been rock solid on the bench... but I was paranoid so I got an R6014HS. Well? I unplugged the R7008SB, I linked the R6014HS to my 14SG and also set the 6014 to HS. I plugged it into the plane and the sticks didn't move the servos. I turned the RX switch off and on and then the sticks moved the servos. After a few seconds I was moving some wires around and glitch city, then a few seconds later some random glitches... then solid. I was moving the same wires around the same way with the R7008SB. Now I want to run the 7008SB. haha
