Give-a-way contest! Win a Hanger 9 Extra 300X
Status
Not open for further replies.
Seabee
Looking forward to expanding into the large scale world of this hobby.
With all the experienced pilots and builders will make it that more enjoyable.
Thanks for letting me join your group.
F82FAN
Love my Hangar 9 birds!
F82FAN
It would be great to add this one for my son to have his very own.
F82FAN
We love Warbirds and 3D stuff.
Even our 1/3 scale glider-towing Pawnee is in regular service.
Vebbyson
Foam-Core Wings
Oversized Control Surfaces
Painted Hatch
Pre-Drilled Firewall
Genuine UltraCote® Film
Removable Wings and Tail
Foam-Core Wings
Painted Hatch
Pick me!
Status
