Give-a-way contest! Win a Hanger 9 Extra 300X
Status
Not open for further replies.
jellen
Foam-Core Wings
Oversized Control Surfaces
Painted Hatch
Pre-Drilled Firewall
Genuine UltraCote® Film
Removable Wings and Tail
OMG! How awesome would this be under my Christmas tree???????
butch
I have a bme 116. will that be enough power for this ship? if so I hope to find it under the tree this year.
Status
