I have to agree!Too hot for Cappy to want to fly and put big airplanes together!![]()
No I don't think I would be flying when it is that hot. The engine is up to temperature before it is started. I think I would be staying home in the air conditioning.
It's supposed to be a lovely 105 degrees here today.I always suspected Illinois was really communist hell.
I really like the cans on my planes. Did you find on your Extras that you had to do a lot of compensation to get the cg to a satisfactory level? I have an EF Extra 300 88" that I am planning to put a can on (it had one years ago before I got it), but the plane is balance so nicely right now that I really hate to have to compensate a lot.For what its worth: I have used cans for most of my planes over the last ten years. All of them had a cg that was farther aft than the same model built with stock mufflers. The models that had the furthest aft cg's were the Extra's. While my Edge models had an aft cg, the Extra having an already longer fuselage just makes the problem worse.
I could always use the excuse that I need another plane for the DA 60 with the canister setup because the CG is WAY off with a can![]()
Yeah if we could get rid of Cook County and about half of my County, St. Clair, this wouldn't be a bad state.I had to fix your quote to make it a little more accurate. It's a shame too as everything that isn't Chicago is really nice except for your Commy policies. Chicago on the other hand I am pretty sure is hell on earth.
