IMAC Written Call Sheets
Discussion in 'IMAC>>>Aircraft, Techniques, Equipment, etc.' started by Kevin-Young, Oct 27, 2014.
  1. Alky6
    Alky6 150cc
    Good catch. I missed that.
  2. Krzy4RC
    Krzy4RC GSN Contributor
    Figure 5 - Pull to vertical, 1/2-roll centered on vertical, push a half-loop, 3/4 roll centered on down-line, pull to upright exit.
  3. Krzy4RC
    Figure 6 - 1/2 Reverse Cuban
  4. Krzy4RC
    Figure 7 - Push/Pull Loop - 2 lines indicate the roll is to be centered at the apex of the loop.
  5. Krzy4RC
    Figure 10 - Reversing P-Loop - Pull to Vertical, 1/2-roll cetntered on vertical, push 1/2-loop and immediately pull 1/4-loop, with 1 positive snap after 1/4=loop, exit upright.
  6. Krzy4RC
    also, 90' is 90 feet. You want 90 degree
  7. Alky6
    Alky6 150cc
    Thanks!
  8. I always make sure to tell the pilot cross-box if the exit is cross-box. Helps ease the nerves when you are looking at either the belly or canopy after the rolling manuever :)
    Krzy4RC and Alky6 like this.
