Very nice....OK. Back at it. Had to fix the temporary build table and turn it into the final one. I had about a 1/16" belly in the middle. That is fixed and now it is flat, flat, flat with no twists. Got the motor box glued to the fuse top plate and then the fuse sides glued up. Used heavy aluminum straight edges to keep the top of the fuse sides aligned with the top fuse plate. Bonus of using a sacraficial piece of 5/8" gypsum for the top is using pins! Also added some extra plywood for the rudder servo screws. Going push-pull with a single servo
View attachment 9855 View attachment 9856 View attachment 9857 View attachment 9858 View attachment 9859 View attachment 9861
