Lets chip away a little at that list of remaining last minute items shall we? I got started this morning with a quick 15 minute swap. I added the TDRC Anti Vibration Ignition mount to the dub 70 twin ignition module. Nothing real big about this task. Remove module from top of motor box, drill (4) 1/16" holes, harden with thin ca, place "AVIM", screw into place and replace ignition module. Done!
Next, I have been thinking about a "pulse" tube for the front of the carby as I have seen others have issues in the past with an unbalanced air flow and negative air pressure affect the operation of some engines. Though I don't do this on any of my other engines, My friend I got the 70 twin from did have some issues with it until he ran a line inside the fuse to equalize the air pressure. I have heard...(though I don't know if it is true) the 70 twin was a little finicky sometimes. We had never seen that but what the heck, easy enough to do and could be a good insurance policy. I don't need this heavy paper weight falling out of the sky. First, I ran a Tygon fuel tube looped around the front of the carb, back along the carb fuel feed line and terminated inside the canister tunnel with a felt clunk attached to the end then zip tied to the cross bracing of the bottom of the motor box floor. It should breath air quite nicely and keep that diaphragm balanced well.
The instrument cluster has had me pretty bothered so I fixed that little annoyance. Not perfect, but it will work and I am not going to worry about it any longer. I will say this, if I ever do a larger build project that I have to fashion and manufacture any sort of gauges or instrumentation, I will simply find some bad ass gauges and buy them.
After a little snacky-snack of left over Broiled Rib Eye steak, I attacked that darn spinner. I really don't like cutting spinners because in the past I have had some that didn't turn out too well. But I guess experience and practice has some how finally paid off. I do like using the "Nibbler" tool though. It certainly does make things a lot easier and so much quicker.
With the first of "MANY" bites taken out of the original prop openings, I started chewing away the entire radius of the prop opening.
I ended up taking out about 1/4" of the opening all the way around from leading edge to trailing edge. Once that was done, I used the small drum sander on my dremel tool to finish up the shape and to smooth out all the rough teeth, (and let me tell you it had some pretty knarly teeth) all the way around. Once shaped, sanded and final size was acquired, I washed the spinner with warm water and dish detergent then bolted it in place. I have three different kinds of metal polish I use for different projects. I chose my Blue Magic for this one. Rub it on with a soft cloth, allow it to haze...then polish it off.
Oh my...!!! Ok, I will keep this one. I like how it came out. The cut and shape of the prop openings is "juussst" right. I am pretty pleased with this one.
There we go. A few more things removed from the never ending Pitts build list. LOL. I will probably start baffling the engine tonight and doing a final fit of the cowl as well. I would like to get the engine compartment completed so that all I have to worry about is paint the cowl and add the "dummy" radial decal to the face. I may....install the canopy over the next couple of days. I would really like to have the pilot bust in place before I do so, but I feel there will be plenty of room to slide him into place when he becomes available. I think at this time I have decided to "not" paint the bracing support along the front top of the canopy. In looking at all the single seat Pitts, they had a complete clear canopy. Guess we will see for sure when I get it placed.
More to come and almost done.
![Big Dance :banana-dance: :banana-dance:](/styles/default/xenforo/smilies/big dance.gif)
