PAU 30% Edge
Phil.Griffin
DA ignitions are made in Australia.
The new ignition for the DA-35 has JR/Futaba connector receptacles right on the enclosure, one for the hall sensor, one for the power.
It is also high voltage rated.
For security, I hot glued the connectors so they don't accidentally pull out...
I am soooo glad DA is trending towards HV ignitions...
sweetpea
I know the one DA ignition I have, I switched the connector. Most people I know do. Hopefully all future versions switch over.
Dan767
The connectors are Powerpoles and are well liked among Amateur Radio users (me) and other electronic hobbyists. www.WestMountainradio.com carries them and the tools to install them should you ever want to use them. They aren't cheap and they handle high current very well. FWIW.....
ericb
Team WTFO
I have used them in the past. They are good connectors, just too large and not enough people use them to be a "standard" plug. Most people just cut them off and use a standard JR type plug.
Tseres
There is nothing wrong with the connectors that come from DA. I agree 100%. I never said that there was a problem with them. The problem is that you have to reduce that connector to a JR or Futaba plug. That is what our JR Futaba or any other systems come with. So if you have to do that anyway. Why not build it in to begin with?
Astrohog
The Anderson Powerpole connectors are actually very good connectors........BUT.......they are HORRIBLE in this application. It is not the connector that fails, rather the wires break due to not having any strain relief. If one were to fill the backside of the connector with silicone where the wire enters, it would last for a very long time. I have had one fail on me (during a low hover) and it resulted in a total loss of my FIRST PAU 50 cc Edge. I have replaced the Anderson connector on every DA I 've had since.
Regards,
Astro
Tseres
I got the New DA-60 fired up in the Prototype Edge. I presoaked the Diaphragm in the carb 2 days ago but something came up and I didn't have time to start it. I had the time today. Fired on the first Choke flip. The low end was lean and had to be adjusted. This is actual time of how long it took to tune it.
Tseres
It's official. The Prototype Edge with the New DA-60 is flying again.
It flew great. The power was out of this world. Great Combo. Had 3 flights and everything worked great.
