Have you noticed the 330 seems like a bigger airframe all the way around for the same size as her counter parts. i.e., 300, 260.
Compared to the EF91 the cowl on mine is bigger in height. Like wise compared to the V1 I had. I can see that about 1.5 inches has been added to the height where the cowl fits on the fuse or F1. And I added a 1" shim block to the fuse for the LG so prop clearance would be acceptable on the V1. I don't see the entire fuse though being any larger than the EF 91" 300. I understand what you mean though. Yeah, "overall" the moments on the 330sc are a bit more exaggerated than say the 260 and 300. On my EF 104 I thought the tail section was a bit undersized compared to the rest of the fuse.
I definitely like my old covering scheme better though that was on the V1......
