Pilot 35% Yak teardown/ replacement
Discussion in 'Giant / Scale RC General Discussions' started by dhal22, May 13, 2019.
  1. dhal22
    dhal22 GSN Sponsor Tier 1
    I do have upthrust. Squared the plane then found the right height for the laser. Probably start with a fender washer behind the 2 top engine mount bolts. 20190908_102852.jpg
    pawnshopmike and WMcNabb like this.
  2. dhal22
    Made some quick 1/8" washers out of G-10.
  3. dhal22
    The plane is definitely square/ level.
    AKNick, pawnshopmike and WMcNabb like this.
  4. dhal22
    Too much I think. Maybe drop down to 1/16" washers. Before and after.
  5. acerc
    acerc 640cc Uber Pimp
    2,904
    4,572
    113
    Florida
    The top pic look's like the laser is on the top of the plug and the bottom of the prop shaft, up-thrust. Not enough in view to comment on the bottom pic.
  6. dhal22
    Laser and plane are in same location in both photos. Just the prop shaft has moved. I'll get a better photo.
  7. dhal22
    Made some thinner washers. Also added spinner bolt to enhance laser effect. Looks dead level across the plane. I think I will add fender washers to the G10 washers and make some downthrust.
    acerc and pawnshopmike like this.
  8. dhal22
    Added more washers, now I have just a touch of downthrust. Amazing what an 1/8" or less can do.
    WMcNabb, pawnshopmike and acerc like this.
  9. acerc
    2,904
    4,572
    113
    Florida
    That looks much better, the laser is centered on the plug and the prop shaft.
  10. acerc
    2,904
    4,572
    113
    Florida
    Beautiful!!!
