Pilot 40% 330 Recover and Build
Discussion in 'Giant / Scale ARF Build Threads' started by stangflyer, Nov 28, 2017.
  1. Snoopy1
    Snoopy1 150cc
    2,418
    3,124
    113
    Canada
    Did not see you mention it or I missed it to take out stubborn dents in balsa wet the area down let it sit for a couple of minutes and then go over it with a hot iron the water must steam out of the wood and you will then get the stubborn wood dents out just a suggestion.
    49dimes and stangflyer like this.
  2. stangflyer
    stangflyer I like 'em "BIG"!
    No flying today so that means a little progress on the 330 today. I got the base color covering on the remaining stab/elevator and rudder. Quite basic, but at least I am making a little progress. I am probably strip the wings and forward hatch/canopy tomorrow. So far I am up to about 20 bucks for the white covering. I figure I still have a 10 meter roll of white to order and then the colors for the rest of the scheme. Which by the way, we now have a scheme. What is it you may ask? Ah, but I can't say yet. Hee hee.
    I must be getting slow. Either that or I am taking my time. Which ever, a very therapeutic day of covering.
    Jetpainter, 49dimes and pawnshopmike like this.
  3. Snoopy1
    Snoopy1 150cc
    2,418
    3,124
    113
    Canada
    You got a start on it that is what counts, there is still some time left in the season to get it done.
  4. Snoopy1
    Snoopy1 150cc
    2,418
    3,124
    113
    Canada
    Just remembered you were posting playing with carbon on another plane you need to say focused on getting this one done and for that beautiful red head she would like get to play outside as soon as possible.
    stangflyer likes this.
  5. stangflyer
    Hey Fellas, back to doing some covering on the Pilot 330 this afternoon. I can't tell you all just how painstaking this scheme decision has been. But finally, I have arrived on a scheme. I am doing a little altering to fit my wants, however the jest of the chosen scheme will remain fairly consistent with the original. (I think) :laughing:I have just about gone nuts looking at planes on the internet. Some of them were quite nicely done. Some of them just too blah. (in my opinion) Some of them too widely used. As you all may remember, I wanted something that has not been done or at least not widely used. I actually only found one rendition of the scheme. And just for sanity reasons, I am going to keep most of the scheme undisclosed at this time. Why? Well, cause I know I will go completely insane if I discover the scheme has been done "before" I get the 330 covered. Once it is done? Well I guess it will be just too late then won't it? hearty-laugh.gif
    I figured the best place to start would be the bottom of the stabs/elevators. Mainly because they are already covered with the base color. Plus, it will pretty much set the stage for the rest of the scheme over the entire airframe. Some of you may remember, but for those that don't or have not visited the thread, My colors for this scheme will all be Ultracote colors. HANU870: White, HANU903: Apple Green, HANU881: Silver and HANU874, Black.
    I also figured that if I don't like how it looks, what is put down won't be that difficult to remove. I did originally plan to do the bottom of the plane in the same scheme, (just different color) as Brad Wurstens MXS-R. Oh I would love to do that as I mentioned. However after looking at it, thinking about that "slanted" or scewed checkerboard, I just don't think I have it in me to cut all those silly squares at an angle and then lay them down. So what did I decide? My own style of the scheme that I found. I started by drawing out my lines on the bottom of the right stab/elevator. And once they were precisely drawn onto the bottom of the structure, It was time for the first stripes.
    One at a time first the Ultracote HANU903 Apple Green, then the Ultracote HANU881 Silver. Back and forth and back again. Stripe by stripe, the color was starting to unfold.
    Once the green and sliver were down, it was time to put the larger width Ultracote HANU874 Black.
    First one, then two black stripes.
    And (4) hours later, I have a completed bottom right stab/elevator.
    So as to allow for some overlap of each color to insure a good lip seal, the green and the silver stripes are 7/16" wide. This gives each color an over lap of about 1/16" to 1/8". The same overlap was allowed for the 3 3/16" wide black stripes.
    I had thought about using the widely used Windex trick to lay down the black stripes so I wouldn't get any blisters or gas pockets underneath. However for such a small area, I relied on my old stand by technic. Shrink the base (White) real tight. Turn down the heat on my iron and slowly lay the black stripe down from one end to the other while working it with the iron. I must say, it turned out rather nice.
    For the rest of the plane, (especially the top) I should not have to worry about any blisters or gas pockets. As the top will be split into sections of one color meeting with the next color.
    A small side note: I decided on these colors mainly because I miss my Behemoth Yak (1). It looked pretty bad ass two inches from your face in a hover. Something about those colors together just really seem to make the whole plane "POP". On the ground or in the air...it looked pretty sweet to me.
    That about does it for now. I'm going to try to get the wings stripped soon. Maybe tonight. I know... said a while back I would get to them. Just haven't had much time. LOL
    Jetpainter, HRRC Flyer, acerc and 4 others like this.
  6. Looking good! I love the color combo.
    49dimes, dhal22 and stangflyer like this.
  7. stangflyer
    Thank You Mike. I hope the entire covering scheme turns out as amazing as I see it in my head. But we've been down that road before haven't we? What is in my head can be quite scary. LOL
    pawnshopmike likes this.
  8. dhal22
    dhal22 GSN Sponsor Tier 1
    I like it.
  9. stangflyer
    Thank you.
    dhal22 likes this.
  10. Snoopy1
    Snoopy1 150cc
    2,418
    3,124
    113
    Canada
    That’s a good start. It is looking good. Just a matter of persistence and patience you will end up with beautiful plane.
