witchfingers
I just downloaded the programing manual for that bad boy. I will read up on it. Thanks Yakken.
You program everything with the eq10. No pc needed.the programmer is built in it.Good to know. That will save me some time for sure. Does it hook up to the pc or does it have a programmer?
When you say ''y's", do you mean y harness the inner aileron servos right and left and y the outer aileron servos right and left?I ran Y's for many years, long before balancing features in our radio systems for Ailerons and Rudder. Sure, you can't match the end points extremely well, but you can get it "very close". I never noticed any issues with the Y's. I'm even considering doing a "Y" harness set up again, just to prove that it can still be done.
It can be done. But from what i seen was when you trim the planes out then take a flight. Your trim might be a quarter inch off. Everytime you correct it and fly when you land they were always off again.I ran Y's for many years, long before balancing features in our radio systems for Ailerons and Rudder. Sure, you can't match the end points extremely well, but you can get it "very close". I never noticed any issues with the Y's. I'm even considering doing a "Y" harness set up again, just to prove that it can still be done.
I am not sure if they are saying run a y harness to right and left ailerons like a parkflyer. That I don't think would work very well. The servos would definitely fight each other.
If u want to program the servos i would go with a eq10. Its mutch easier than programming using the hitec programmer. I have programmed them both ways.
