Xpress
Hitec recommends against running two receivers. The receiver can handle up to 30 volts. Some guys run a y harness to a servo. One end goes to the servo, the other half of the y goes to a reciever battery. Every channel could have its own battery technically. The hitec receivers are basically a power expander themselves.
I heard that on the a9 to. Wonder if they still say dont run two rx with the a9x?
You can run 2 receivers with the 9 or 9X if you want, they just can't be Optima receivers as the telemetry information coming from 2 receivers will cause interference. I don't recommend Minima receivers on big airplanes though.
The Optima receivers can handle up to 35 volts through the SPC port only, otherwise max voltage through the servo ports is 9 volts. The SPC port only powers the receiver, you will need to provide separate power to the servos if you utilize the SPC port. We use the SPC port to tell us what our flight battery voltage is (utilizing a jumper tied into the ESC's battery leads) and we set an alarm to notify us when the flight pack voltage drops below a threshold. No more setting a timer, it's based off of the actual voltage.
As far as y harnesses, I am not sure if they are saying run a y harness to right and left ailerons like a parkflyer. That I don't think would work very well. The servos would definitely fight each other.
You would run a y-harness to the left wing panel to tie the left aileron servos together into 1 channel, and run a y-harness to the right wing panel to tie the right aileron servos together into 1 channel. The servos will fight each other if you don't re-program them, which is what we always recommend doing. RC car guys do this all the time with twin steering servo setups as they only have 1 channel for steering (yes they burn them up but because they don't program the servos so the center and end points match). There is no issues with doing this, and this is how several of our team pilots have their giant scale (up to 40% even) airplanes setup.
