Problem with 30cc Sbach sugestions please
I have a well built Sbach, it seems straight, balanced , working radio gear and an OS GT33 engine
The plane seems to fly straight and level trimed out. The problem is when I add elevator in a turn
the plane tries to roll severely in the oppisite direction of my turn. And when I start a loop the plane tries to roll
severely even though the ailerons remain nutural. Anyone having this problem?
Thanks for any help. Bob
Suds
I'd look at the dual elevator servo setup and eliminate any issues as that would seem to be the most likely place (in my mind) that could be causing the problems you are experiencing.
Bushwacker
3DRCF Moderator
What does your servos do if you do this on the ground and go through the motions like your in the air.
Aerobeez
[MENTION=4218]dirtbikebobby[/MENTION] Please reply or PM with your email address.
