Bunky.F.Knuckle
Your table is cleaner than mine was about 2 months ago...... Mine is messy again. Need to get it cleaned off again for the next 3 rebuilds.
You should see mine at present. OIY!!! Time to tidy up a bit and get busy again.Bunky.F.Knuckle said
Man...that isSilvanskii said
Yea boyeee get that thing going again so we can formate! Mine is re-dialed in and ripping now!
FYI for the best bond in the fuse, epoxy on epoxy is the ticket. 30 min works great, especially if you mix in some milled fibers for strength/thickness and/or cab-o-sil or glass beads again for thickness. These increase the air trapped inside and make it cook off quicker to so be aware of that.
My poor gal has had her whole landing gear plate re-installed with a new one and gobs of epoxy with milled Kevlar in it. That gear plate and forward fuselage will be the only thing left of mine hehe....
