Do you use them for break in as well or after break in.
I will be honest, since I started flying in 2006 it took me a while to convert fully to gas engines in 2010. I jumped on the Stihl HP Ultra (full synthetic) bandwagon because I had been hearing lots of great things about it. I admit it worked great for me with the exception of one thing........here the plains of the midwest our weather changes drastically sometimes from day to day. For instance just the other day we flew and it was 80 degrees and we are having lows in the 20's tonight with only 50 degrees if we are lucky tomorrow. We also get variations in humidity that effect things. All this means is that your tune can be different from one day to the next so for us it's often better to run just a tiny bit more rich so you never lean out when you go out tomorrow and it's 20-30 degrees different from yesterday.
With this consideration what happens with Stihl-HP is you have a nice clean piston top but carbon forms in the exhaust port and quite a bit of carbon build up in the mufflers. I switched to Redline at the start of last flying season under peer pressure from several of my friends that gave me crap continuously. It is very curious how it has cleaned out some of the engines that had previously run stihl. Some of the older ones were belching out black crud and finally slowed to less than I was used to. After inspection I found that it not only cleaned out the piston top on these older engines but also the exhaust ports, etc.
Since then I've burned about 90 gallons of fuel and added a couple of small engines, two DLE120's and a DA70. The DA70 was flown A
LOT last year and not treated with the most respect as I pretty much flew it like I hated it from the beginning. After burning a ton of fuel, I sent that engine to DA for a Winter checkup and the reed update. Came back with a perfect bill of health, absolutely no crap on the piston, ports were clean, mufflers were not built up with anything.
To answer the question that I quoted, I do not run a break-in oil because I burn enough gas and the power gain at the point of "break in" is minimal compared to other factors so I just let the break in more slowly on the Redline. I can only guess I had 100+ flights on my DA70 as an example and there is nearly no crosshatch visible. One of my DLE120's had probably 50 flights on it when I had a muffler off and it is roughly half broken in.
Needless to say I am impressed and will be staying with Redline from here on out.....
