Can you describe what not working properly means in this case? Not powering up, can set it up of communicate or doesn't work as expected, etc.
I can get it to startup and work properly but not always. I put it away for a year or so from frustration. The other day I decided to give it another go. Fiddled with it for a couple days nothing worked. So connected it to my pc and reset the gyro back to original setup from the factory. Installed it back into the plane everything worked except the rudder this time. With gyro turned off everything worked as it should. But when activated the Gyro the ailerons and elevators worked properly but the rudder was backwards. No matter what I did nothing work. Pulled it out of the plane back to the PC and check everything found nothing. Did several reboots nothing the rudder kept going the wrong way. Went back to Demon Cortex to ask for help that was a wast of time. Never got a response, so much for doing business with them again.
