Can you describe what not working properly means in this case? Not powering up, can set it up of communicate or doesn't work as expected, etc.
I can get it to startup and work properly but not always. I put it away for a year or so from frustration. The other day I decided to give it another go. Fiddled with it for a couple days nothing worked. So connected it to my pc and reset the gyro back to original setup from the factory. Installed it back into the plane everything worked except the rudder this time. With gyro turned off everything worked as it should. But when activated the Gyro the ailerons and elevators worked properly but the rudder was backwards. No matter what I did nothing work. Pulled it out of the plane back to the PC and check everything found nothing. Did several reboots nothing the rudder kept going the wrong way. Went back to Demon Cortex to ask for help that was a wast of time. Never got a response, so much for doing business with them again.
Have you tried setting up the rudder opposite during the 2x and 1x green blinking light session and see what happens?
No I have not will tried that interesting thought, feel kind stupid that I did not think of trying that thanks will give that a go.
Tony have to ask have you had a PowerBox Atom radio in your hands.
My Power Box experience was brief. I won a club raffle prize of 1-2 hours of instruction with Extreme Flight pilot Antonio de Souza and he uses PowerBox transmitters. That transmitter is amazing but I couldn’t pass up a great Futaba 18SZ deal. No further experience with PowerBox…..
