-Rick-
Elevator done. used gorilla glue instead of the west epoxy system. Epoxy would work much better if using the vacuum system or putting 400 pounds of weight on the parts!
Elevators are done, turned out much nicer then the rudder when using epoxy.
Also added a 1/64 ply strip to the back and bottom of both elevators to hopefully stop some of the "dings" while moving it, like putting it in the van. Did not like that it only had 2 millimeters of balsa on the trailing edge, I know that I would damage that real quick!! This was latinated under the balsa skin.
Almost done. Saved 1.5 oz.
Yup, the way to go for me! Next the wings!!
