BUT, can you do spoilerons and still be able to do crow? I was able to get to what you have but then could not get spoilerons to work, then when I get spoilerons to work I have not been able to get crow to work. Has to be a way, I just have not figured it out.
Or as @SleepyC says......
@orthobird here is the vid I was going to share. The flaps par is right at the end, I was having too much fun and forgot about them. With no wind and a little more setup I'm running 75% flaps and add a little throttle and you can almost jog next to it down the runway with the plane at about 12" off the ground. It's so fun.
Plus.....after four flights I'm putting back in an average of 250-300mah less into each flight pack. That means the little bit of fighting that may be left in the servos is gone.
