I was going to buy Promodeler servos until I read some posts by Promodeler about compatabilty issues with Spektrum PowerSafe receivers. I emailed them and got a long email back about why I shouldn't use the radio equipment I've been using without issue for years. He said the problem was fixed, but gave no explanation of what the fix was, then went on and on about his dislike of Spektrum. I just decided to stick with what I know works.Well you decided to go Hitec again did pro-modeled cross your mind.
Thanks for that I fly Spectrum as well so that is good to know. So if it does not work with his servos it is a Spectrum problem????I was going to buy Promodeler servos until I read some posts by Promodeler about compatabilty issues with Spektrum PowerSafe receivers. I emailed them and got a long email back about why I shouldn't use the radio equipment I've been using without issue for years. He said the problem was fixed, but gave no explanation of what the fix was, then went on and on about his dislike of Spektrum. I just decided to stick with what I know works.
Evidently they do have issues, but it's only with some servos. Spektrum certainly isn't perfect, but the reliability with mine for the last 8 years has been, so I have no intention of fixing what's not broke if you know what I mean .Thanks for that I fly Spectrum as well so that is good to know. So if it does not work with his servos it is a Spectrum problem????
I finally treated myself to a good quality set of allen drivers and Made in the USA!
You know your going to have to get the metric set as well. And while your at it get a second set of each for the tool box.I finally treated myself to a good quality set of allen drivers and Made in the USA!
Isn't that the same line used on their threads, "Evidently they do have issues, but it's only with some radios."Evidently they do have issues, but it's only with some servos. Spektrum certainly isn't perfect, but the reliability with mine for the last 8 years has been, so I have no intention of fixing what's not broke if you know what I mean .![]()
As do all radio brands.Isn't that the same line used on their threads, "Evidently they do have issues, but it's only with some radios."
Sorry! Just had to do it...![]()
