I think that should hold up now.Worked on getting my CHEAP HK plane in to shape.
View attachment 53623 View attachment 53624 View attachment 53625 View attachment 53626 View attachment 53627 View attachment 53628
I think that is what happened to the motor in my Trex550e. I pulled it apart after a crash and the bearings were shot. I installed bearings and a shaft and checked the magnets and everything looked fine. But when I test ran it after just a few seconds the heli started shaking violently. I could see the motor can shaking so I pulled it back apart and two magnets had come loose and moved causing a bad balance issue. I'm sure the crash helped it along to.Honestly, looks like a bearing went south, and then overheated and heat developed loosened the magnets.
Thanks found them at Toledo and bought a pack you were correct from Dubro and the number thanks.Hey there Snoopy1, those look like Dubro Heavy Duty 1/4 scale hinges (Dubro part # 257). They come in a package of 15 hinges with cotter pins as in the attached pics. I take the cotter pins out and replace them with .047 music wire to get remove-able controls as shown in the attached photo. Just use some tape to hold the 90 degree bend in place and you're done.View attachment 53547 View attachment 53548
If you don't find them in Toledo let me know. I have them in stock.
Thanks for the offer found them at Toledo but you stated that if not that I could buy the hinges from you are you hobby store or what and your contact. Thanks.If you don't find them in Toledo let me know. I have them in stock.
Glad you were able to find them. Use .047 music wire in stead of the cotter pins and you will have removeable control surfaces.Thanks found them at Toledo and bought a pack you were correct from Dubro and the number thanks.
Hi @Dennis9412 well thanks for the help. By the way Re built the lift bridge at port carling in 2008 big job near you.Glad you were able to find them. Use .047 music wire in stead of the cotter pins and you will have removeable control surfaces.
