Looks good to me.Recovered my wing tonight. Ultracote true red wasn't a perfect match if you look directly at it (or maybe it is and it's just the layers of red that throw it off?).
View attachment 54033 View attachment 54034
Either way I'm happy with how it looks. Plus in the air, the only thing that matters is the skill![]()
EPP or EPO? Typically EPO can be re-molded using the 'Elapor soup' method but EPP is a bit tougher and usually you just need to bend it the opposite way.
Soup? Well it's like this. Get yersef a big boiling pot. Stoke a big ole fire 'neeth it. Insert cheap foaming into pot. Bring to a brisk boil. Wa-laa...R/C Airplane Soup. Not to be confused with alphabet cheeseburger soup.I believe it is the EPO Tanner. I think my QQ is the EPP. So what is this soup talkin?
The "Turbo" spinner showed up at me door.......
ran it to check its awesomeness and discovered the bearings in the new motor have gone south
...........Guess my CHEAP HK plane has got some more shop time
.........Did I mention this plane is NOT cheap at all!?.........
Yep every thing smooth as silk until 8k rpm then it shakes like a vibrator. I can move the shaft up and douwn as if no bearings at all???.......I wonder if the stator bearing housings have cracked ??? will know soon enough but my zeal for electric is going crapola real fast. All these issues are just a bunch of frogs on the lily pads in my lake of pain
View attachment 54098 View attachment 54099 View attachment 54100 View attachment 54101
