6172crew
Are you dead set on 8s? What type of flying do you want to do. high or low energy? The 4330 is a wonderful choice as it is lighter than the A60-5S fo about the same power and cost. Just pick a wind that works for you. Also the Hackers are pushing the size limit on the e-box with the x-mount being wide. I am considering e-converting mine and I have a A60-7S laying around, but I am not sure how much work I have to do to get it to work. I got a different ARF for a float plane I think I will use the motor on, so I am considering getting a 4330 myself.
I'm not dead set, the difference between the 6s (380-400kv) and the 8s (282-300kv) seems to be around $100 because the esc jumps up that much for the 8 cell. You do get a little bit more power and the batteries are probably cheaper to get for the 3 cell vs 4 cell. I'm looking to find a big prop and slow speeds. I don't own any batteries that will fit this plane yet so that wasn't even a factor in me leaning towards the 8s. I read through both threads, here and rcg and couldn't really find much info except the 8s guys blew wigs back at the field so I was thinking about blowing a wig or two at our field.
