		how do these look?
I figured the gold lightening bolt would look nice on the white center of the wing, and match the trim. We could also size these for each aileron, or event the fuse.
how do these look?
wow Gary you are getting to be quite the graphic designer!
If you set an idle so the prop never stops spinning that helps a bit. If all else fails reset it to default, it should have pretty good response. An idle up definitely makes a difference though, especially when going from low throttle to full really fast.
Idle up done still no differenceI really don't know wats goin on here
