Rolling.Circle
Thanks again. Flying is pretty much our whole everything as you may have guessed. Aaron works hard between IMAC and his 3D. Just turned 12 and he is flying in NC next month in Sportsman for the Eastern region's world qualifier. That's the top 4 from the NE against 4 from the SE to pick the top 3 to go to the World's next year. Wish him luck.
FWIW We are using 2S 800mah, flying about 5 minutes and putting 650 - 700 mah back in on charge up... shocked that it eats that much mah but Aaron is working the plane quite a bit on the 9x prop. 450 mah might only yield 4 minute flights depending on your flying style.
