betoperez
I built this profile around May this year and It might have 60 flights. The fuselage is base on 2 rails of 3/16 aircraft plywood that run from nose to tail. the wing area is about 1,237 sq. in. ( 8.5 sq. ft.), spans 66 in. root is 22.5 in, tip is 15 in. weights about 7.5 lbs. the engine is an OS 110 four cycles and is swinging a 16/4 W APC.
Here is a video http://youtu.be/2rC7jMtyJQk the only video I have.
This is so you can see the size.
Working on the fuse structure the next one will have two 1/2 in. fiberglass rods as a substitution for the plywood rails.
Didn't know what prefix to attach.
