Aerobeez
Hi pilots! Welcome to your Aerobeez 93" Extra 330SC Full Build Review! In this build, Pete will take you step by step through the full build! Many of the tips may be applied to future builds of other ARF's!
Here are a few things from your builder Pete.
Hi friends! First off, I would like to welcome you to this build! I am very excited about this new 93" Extra330SC! This is sure to be an exciting aircraft with a ton of aerobatic potential! In this build, please keep in mind that these are the steps I take when building a large scale ARF. Steps may be duplicated from area to area and steps may be skipped and returned to depending on how you best like to layout your build. The steps and tips here are from my personal experience. You may use this build as a general guideline if you wish to progress with your own build layout. If you have any questions or suggestions, please visit us on our Facebook Page and YouTube Channel. You can post messages for us on our social networks and or contact us via email.
- Pete -
Step 1
Let's start by locating your main landing gear components. I always start the build by first getting my fuselage on main gears. This makes the build much smoother.
Step 2
Notice the angle of the carbon fiber main landing gear. The leading edge will be straight (pointing towards the nose of the Extra) and the trailing edge will be tapered (pointing towards the tail of the Extra.)
Step 3
Use blue thread lock and attach the main gear to the fuselage. The main gear "blind nuts" are factory installed. Note the landing gear "cover" first followed by the screws to hold the cover and the main gear to the fuselage.
Step 4
Install the landing gear fairings on both sides. Test fit one at a time. You will find that they are side directional and will fit better on one particular side. I chose to use an adhesive called Shoe Goo to glue my fairings to the fuselage. You may choose to use small self taping screws (not included) on the bottom if you do not want to use an adhesive. You may also choose to use CA or Epoxy. Shoe Goo is easier to peel away if in the event the main gear needs to be removed.
Step 5
Install the wheel axles.
Pete's Tip: If you have a skateboard skate key, they work perfect for installing the wheel axles.
Step 6
We include high quality re-buildable aluminum hub wheels in each 93" Extra 330 SC ARF!
Step 7
Use blue thread lock on the wheel collar set screws and install the wheels onto the axles. You will use 2 wheels collars per side. If you are experiencing a tight fit in getting the wheel collar onto the axle, check the inside wall of the wheel collar. There may be residual "flash" from the threading process for the set screw from the factory. Use a round file or coarse sandpaper rolled and you can sand the interior diameter of the wheel collar until you have a clean fit.
Pete's Tip: Do not fully tighten the wheel collar at this time. You will need to adjust the wheel/collar position to fit center between the wheel pants. Keep the set screw position pointing vertical and this will make adjustments much easier at a later time.
Step 8
Use blue thread lock and install the wheel pants. The blind nuts are factory installed. When the wheel pants are installed, adjust the wheel position and tighten the wheel collars. Be sure the wheel spins freely.
Step 9
We will now install the rudder to the fuselage/vertical stabilizer. Be sure to test fit the hinges to the rudder and vertical stabilizer first before applying glue. Included are high quality flat on hinges. Three will be used for the rudder.
PLEASE TAKE NOTE: One of the hinges is pre-cut on one side shorter. The shorter side is to be used on the bottom of the 3 hinges on the RUDDER SIDE.
Step 10
Use a drop or 2 of oil onto each hinge pin area. This will prevent the adhesive from adhering to the hinge. When you are satisfied with the hinge fitment, glue one side of the hinges FIRST to either the rudder or the fuselage FIRST. When the Epoxy has cured, proceed in gluing the hinges to the remaining surface. I choose to glue to the rudder first. Please use Epoxy for the hinge applications.
Pete's Tip: Please use 15 Minute Epoxy as the fastest cure time at minimal! 20 or 30 Minute Epoxy is even better! Do not rush the hinge installation on any of the surfaces by using 5 Minute Epoxy. Especially the Ailerons! There are too many hinges to align and if 5 Minute Epoxy is used, you may find yourself with not enough working time to align the hinges before the Epoxy cures and you cannot move the hinge!
Step 11
Once the rudder has been glued to the fuselage/vertical stabilizer, turn the fuselage upside down and locate the three holes for the carbon fiber tail wheel assembly and the one hole for the rudder to tail wheel guide post. The three for the carbon tail assemble are pre-cut with blind nuts installed. Remove the covering with a hobby knife on all four holes.
Pete's Tip: You can use the flashlight method to locate the holes or use the finger pressure method as I did. Press down and you will see the hole indention. Mark it with a marker and remove the covering.
Step 12
Locate the Carbon Tail wheel assembly.
Step 13
Using a 1.5mm allen tool, (blue thread lock on the set screws is recommended) center the tail wheel and tighten the wheel collar set screws. Now install the tail wheel assembly to the fuselage.
Step 14
If you have not done so already, locate the two slots per side for the rudder pull/pull control surface horns.
NOTE: You have the option on using a pull/pull rudder system with a single servo in the fuselage or a single rudder servo directly mounted in the tail of the fuselage with a single pushrod to the rudder. The parts are included for both of the rudder style set up. I removed both the single rudder servo area covering and the slot for the pull/pull cable set up. You do not need to remove BOTH. This is just for visual purposes to show build alternatives. I will be using pull/pull and the area for the rear mount rudder servo will be covered with the included extra Oracover.
Step 15
Test fit the elevator to the horizontal stabilizer. Be sure to check the counter balance gap to the horizontal stabilizer.
Pete's Tip: Use a permanent pen to mark both side locations of the position of the flat pin hinge. This will be your guide as you can only glue the hinge to one surface at a time. With 3 or more hinges, this will keep the hinge in the correct position when you glue to one side of the surface making the alignment perfect for gluing to the other surface.
Note: The farthest inside hinge is pre-cut from the factory on one side.
Step 16
The cut side is to be glued to the elevator in the slot closest to the fuselage. It is cut to prevent from contact with the elevator control arms.
Step 17
Use a few drops of oil on the pin area of the hinges and glue the hinges to the elevators. (both elevators)
Step 18
While the hinges are curing in the elevators, locate the hardware for the stabilizer. We label each making each hardware for each surface easy to locate.
Step 19
Use coarse sandpaper or a rotary power took and "scuff" the control arms surfaces where they will be glued to the control surface. The composite material has resin coating that is best to be scuffed as shown here for the best strength in adhesion. Once you have scuffed the arms on both sides, use a soft towel with some Denatured Alcohol (Rubbing Alcohol may be used as well) and wipe the composite dust away from the arms. Let air dry before applying glue.
Note: The Ball Ends are different for the surface end and the servo end.
Step 20
The control surface side of the ball end will use the additional beveled cone washer as seen in this photo. The servo side of the ball end does not have the beveled cone washer.
Step 21
Install the ball end on the control surface arms and tighten down. Only tighten until "snug". We are using the ball end side as a guide for gluing the control surface arms. The ball ends will be removed after the surface arms adhesive are cured. Press the composite surface arm guide plate onto the arms. You are now ready to test fit the surface arms.
Step 22
Once the arm is in position, use a pen to mark the perimeter of the base. Use a sharp hobby knife and lightly scuff and remove the covering from the plate perimeter.
Step 23
You can now glue your control surface arms onto the control surfaces. We suggest using 15 Minute Epoxy for best strength. Note: At this point, you may choose to repeat this step and install the control surface arms to the rudder and the ailerons. I chose to continue from surface to surface.
Step 24
Locate the Elevator servo arm slot on the horizontal stabilizers and remove the covering. The servos for the elevators are mounted inside of each horizontal stabilizer.
Pete's Tip: Cut the covering a bit larger and use a covering iron to iron in the edges for a clean and strong finish. When you are complete, we will set the horizontal stabilizers aside until later in the build.
Step 25
Test fit your rudder servo. Pete chooses to drill "pilot holes" for his rudder servo using a 1/16 drill bit. The drill bit size will differ depending on your servo screw diameter.
Step 26
Use a few drops of thin CA in the pilot holes. Allow to dry before installing the servo and servo screws. This will give the screws a much stronger hold to the wood. When ready, install the rudder servo.
