And the green ball links will go with the green Yak![]()
I love my 123 Joe! It's a powerhouse. I'm running the hype pipes, gobs of power.I contemplated a DLE-120, a DA-120, a GP-123, and a BE-124. In the end I went with a GP-123 from http://www.aviatorplusrc.com/rcaviation/ Joe Lewis has a really good reputation.
No problem hovering Joe! The pipes don't hove much of jump, they are pretty linear compared to the others I've used. My Yak comes on about 26 lbs and all of my hovering low and slow maneuvers are well below where the pipe comes on. But like I mentioned it doesn't have much jump.Tell me about the hype pipes, Mike!How are they for hovering?
I'm running 12" header length with a Falcon 27x11 prop. Keep ur throttle linkage linear, which I know you will Honesty I don't fly full throttle unless I'm going vertical, the speed is incredible, even for a boxxy Yak. Prop rip could be a problem if you go a bigger diameter less pitch. I love the setup though, so much fun!
Never seen the 123 with the blue hub. Must be something new they're doing?
Yep those are the ones!
