I was just trying to help you out by giving one of your girls some affection. Harems like that need more than just a single stick ya know
.lol
Though I greatly appreciate the offering of your kind gesture, they all tell me I'm more than enough man and that I handle them all jussssst riiiiight.
Spent a little more time on the Edge yesterday. Got the ignition mounted,
Hopefully it's far enough from the servo to prevent EMF
.Tanner,
I have mounted the ignition modules inside many airframes (My 87" edge being closet to thro servo @ 1" away) and NEVER had any problems . Just make sure the shielded plug wires do not touch anything metal. Looks as if you did a great job there.
Thanks for that good to know. Did not realize that 3W ignition was that sensitive to heat.Some say that the DA ignition is better than the 3W. I'm going to say this......
Greater care must be taken and excercised when mounting any 3W ignition. If you mount the ingitions with the mounting plate down, you MUST have a minimum of 1/8" for airflow. That is basically where the spark is created. Me personally, I mount them upside down, on dowel rods, giving full airflow to that area of the ignition module. If not, then you "could" develop an ignition issue 30-70 flights in.... Case in point. Happened to me and my Dalton 300 with a 157 CS/TS. Both modules mounted the way I described (upside down on dowel rods). Got a miss and poor running conditions. I decided to dam off the ignition modules, from the heat of the engine. And wouldnt ya know, the minute I did that, my issues went away....... Things that make you go hmmmmmmmmm..
Looking good , what are you using for your baffling. Yes I agree to do a good baffling job takes time.Not much done on the 212 baffling. Just a bit of a start is all. This is going to be a long tedious task.
