Thanks Snoop. I got to get "Duck Dodger" made for the "Alien Extra" first lol. Your kind words are touching but I have gotten pretty immune to first flight jitters ( although I do still get them to a degree) If it piles in....:oops:. This thing got saved from the trash can and even has parts pulled from the trash can o_O. So be it if it happens but I don't think it will :rolleyes:. The only reason I'm doing this is to show the FOG's that a "has been wanna be 3D pilot" (who is a right at FOG status himself) can make a "Real" airplane. It will be a good "ICE BREAKER" when confronting the "Temple Elders" for flying privilege's :sneaky:.
Oh! Let me correct myself......Still won't be done yet! lol.....Got the cooling shrouds to make and install, finish the exhaust details and put a 30 or 38cc 4cycle gasser on it:).
Talking about four cycle engines I have a flying buddy the just hates computers and refuses to operate or even learn to operate them any way he asked me to find him a nice four cycle engine with a starter on because he wants to put it on a float plane, and not carry a running engine into the water. Well it took some time but I found one called a Gaui 50cc four stroke complete with starter gas engine. It is on its way will take some pictures of the engine when it arrives.
Actually seen that one run and fly. Sweet engine :yesss:. Looks awesome! What particular plane it going on?
Four strokes rock. I want to build a fun flyer 1/3 Cub and put the Valach 85 in it. Maybe later this year or maybe before I start the Bulldog II, should not take a month to build one.
All I know up to now is that it is going in a float plane he has several. All I know is that the engine had to be between 40and 50cc. I do know he is building a very large Beaver and I remember getting a three cylinder 85 cc four stroke for that plane.
Wow I like that one not too big and four stroke and only 85 cc. Why a cub how about a Taylor craft. And it has a starter.
It was 1/4” x 2” aluminum flat bar. I tapered it down to 1” at the wheels. 6061 I think but can’t remember.
Yes you are Correct the 0.177 is to light it will take off but if you land a little above one G the gear will be flat so need to make some changes. After doing some math it shows that I need 5 mm diameter wire or 0.196 inches. This diameter will carry just on 70lbs in is present configuration. But I cannot find piano wire at 5mm diameter or 0.195” if anyone can help were I can buy the wire is appreciated, thanks.
Actually looked at them as well, with Cubs being done to death it would be a refreshing change or maybe the EMHW Bellanca.
