I have black for the trim. Need to get the surfaces attached before I can paint! Yes, lots happening inside this beast!There is lot going on when that is in the air. Be interesting to see it in the air. The two engines really make it unique. Just make sure you some colour on the bottom all one colour can be confusing when gets a little distance from you.
That is cool sounds good and looks good. Can you help me please I have just got my hands on an 50cc engine with a starter on it but no info on the starter. The only thing I know is that the motor is good for 12 Volt. Can you give some info on the electronic switch you are using to start the engine from the radio. And the size and specifications of the battery you are using to start the engine.
Sent from my Pixel 2 using Tapatalk
I'm using a 3 cell Lipo for the battery. The switches are from Mile High RC. 16 AWG wire soldered to the tabs on the motors and then to the connectors that came with the switches. The switches plug into the receiver. Does that help?That is cool sounds good and looks good. Can you help me please I have just got my hands on an 50cc engine with a starter on it but no info on the starter. The only thing I know is that the motor is good for 12 Volt. Can you give some info on the electronic switch you are using to start the engine from the radio. And the size and specifications of the battery you are using to start the engine.
That solves the problem thanks . Just one more question how many mAh is the 3 cell pack.I'm using a 3 cell Lipo for the battery. The switches are from Mile High RC. 16 AWG wire soldered to the tabs on the motors and then to the connectors that came with the switches. The switches plug into the receiver. Does that help?![]()
That’s one of the coolest things I’ve ever seen!!
