Talking about technical programming stuff just read through the Arora8 info in the plane manual and did not take long I was lost. It will get better I hope when I read the Arora8 manual and have it all in front of me but right now i am like a deer in the headlights.
The one thing that has me completely confused is that they say do not trim the radio leave it at zero all the trimming is done in the Arora8. How is that possible if you stand in front of the plane with radio on and you need trim a certain surface, how do get to Arora8 to make the trim.
Ok Snoop this where it can look complicated but it's not.....
You are setting up the transmitter to operate with the Aura 8. Best to select a new "Model" in your radio to set up. In your radio set your wing and tail configuration to it's most 'Basic" set up it will allow (one aileron servo, one elevator servo, one rudder servo). You then set all the channels that control flight surfaces to a volume of 125% both directions ie up/dn . Set all sub trims to zero. Set the throttle and gear channels to 100% volume. The reason only 100% is because these channels are not "centered" like the sticks that control ele/ail/rud.
Make sure no mixes are active and that no dual rates and expo is set up in the radio. All this is set up inside the Aura 8 and is why you need the configuration tool to see the setup of the Aura 8 or to load a preset configuration as I earlier suggested.
